Slots in nut
Viewing 4 posts - 1 through 4 (of 4 total)
  • #5862
    Moving question over here
    #5835
    CarolynQ
    Hi! The gourd banjo kit is coming along beautifully! I cannot see that the nut has any difference in the width of the slots for the strings. On the video it says each slot is sized for the strings and to make sure it’s put in the right way. Before I glue it, is there any way to tell I have it the right way?
    #5836
    Hi CarolynQ
    In the case of the gourd banjos, the assembly video is a little out of date on that detail. The slots in the nut and the bridge are all equal in size. There’s no wrong way to orient the nut, but you may need to widen the slots for some of the strings, maybe. So put the nut in place and if you can’t get the strings to easily sit in the slots, you can widen with a folded piece of sandpaper like a file.
    Thank you very much for your support and thank you for posting here in the forum!
    #5838
    CarolynQ
    Thank you. That is very helpful. I already sanded a tiny bit so the strings fit.
