Fret dots on the side of my fretless Banjo
Carver Banjos: Instruments Handmade by You and Me › Forums › Customer Support › Fret dots on the side of my fretless Banjo
Viewing 4 posts - 1 through 4 (of 4 total)
  • #6227
    RickT
    Hi Brian I’m thinking of putting a few dots on the side of my fretless Minstrel banjo. I just want to be absolutely sure I have it correct before drilling 🙂
    It says on the Minstrel page that the strings are 24.8 “. I assume that measurement is from the inside of the nut to the inside of the bridge.It is pretty much exactly 63 cm.
    I am planning to put my ruler on the fret board and measure from inside of the nut and marking the fret lengths based on 63 cm total. Does this sound good to you.
    I calculated the spacing on ChatGPT AI
    Hope this is clear. I only in tend to put a few.
    • This topic was modified 1 year, 6 months ago by RickT.
    #6235
    Hey RickT
    The scale length is 24 13/16” to be exact.
    I use standard banjo scale length measurements but take away the first fret. 26.25” standard minus the length of the first fret = 24 13/16”.
    The measurements for standard fret distances is readily available online. I won’t post here because it’s a lot to type out and I’m in inches and you’re in metric, but I’m sure you’ll figure it out.
    #6236
    RickT
    Thanks Brian
    That is pretty much exactly what I used. I put 1/8 inch birch dowels as my dots so they match the maple pot.
    Here is the final product. I wanted it to be subtle.
    Cheers
    Rick
    #6238
    RickT
    Thanks Brian
    Cheers
    Rick
    • This reply was modified 1 year, 6 months ago by RickT. Reason: Posted twice by accident tried to delete one
