Scalloped Minstrel Banjo
$250.00
* This banjo has sold. If you want one like it, contact Brian at carverbanjos@gmail.com.
A unique scalloped fretboard adds a new range of playability. The advantage is that it allows you to play full chords easily while still keeping that fretless feel. Press the string down exactly as you would play a fretted banjo. The combination of the scallops and the nylon strings make playing very easy on the fingertips. Overall weight is about five pounds- easy to carry and easy to hold and play for hours on end.
All parts of this banjo were lovingly handcrafted in a small Indiana workshop. I steamed and hand bent this 1/2″ thick rim from white oak. The skin is tacked tightly into place making the sound crisp and loud. It is a pleasure to play a one-of-a-kind instrument: don’t miss out on this one.
  • 38″ total length
  • 7 scalloped frets
  • Walnut neck and dowel
  • 12″ white oak rim 1/2″ thick
  • Goat skin head
  • Antiqued brass tacks
  • Brass hardware
  • Hand sanded
  • Tru-oil finish
  • Ships in a sturdy wooden box (The “additional information” tab is used to calculate shipping costs based on the package dimensions- the actual banjo dimensions are listed above).
Weight 8 lbs
