IMG_3839
IMG_3845IMG_3844IMG_3839IMG_3841IMG_3842IMG_3846IMG_3847IMG_3848IMG_3849IMG_3850IMG_3851IMG_3843IMG_3852IMG_3853IMG_3854
DIY Banjo Kit
$119.00
The new DIY banjo kit is finally here! It’s everything you need to build your own handmade banjo.
The easy to follow instructions will guide you as you become a banjo maker. No woodworking experience or tools are required. Fun for all ages. Within hours, you’ll be enjoying your new banjo.
Improved design means no need for messy glue or expensive tools. Put this’s impel kit together with just a screwdriver. All hardware is included and all holes are pre-drilled. This is a fully playable instrument with an adjustable head tensioning system.
Perfect for practice at home or in an apartment. Put it together anywhere and enjoy making your own music.
*The tambourine jingles are easily removed if you prefer a more traditional banjo sound.
  • handmade mahogany neck
  • 15 frets
  • 21″ scale length- tune to open A
  • 10″ tambourine body
  • nickel plated tone ring
  • nickel plated tailpiece
  • geared machine tuning pegs
  • detailed assembly instructions
Click here to listen!
